Re: Bad parts
I am not following the firing order discussion.
O-145 and A65 both have 1-3-2-4 order and both using a cylinder number sequence such that even number are on one case half and odds are on the other.
They start the numbering sequence from diagonal corners of the cylinder matrix but the physical firing sequence will be similar.
A65 ; RH_rear->RH_front->LH_Rear->LH_front->RH_rear->RH_front...
O-145 ; LH_front->LH_rear->RH_front->RH_rear->LH_front->LH_rear...
By similar I mean that two cylinders fire in sequence on one side of the case then the two on the other side then start over again.
The difference is the A65 fires the aft cylinder first and the O-145 fires the forward cylinder first but both share the characteristic that when firing moves from LH to RH it also jumps from one end of the engine (fore/aft) to the opposite end.
These sequences seem essentially and effectively the same to me.
