Annual Inspection Checklist
  • Annual Inspection Checklist
    It's annual time. This time I am doing a lot more of the owner-assistance with my IA looking closely over my shoulder. He knows the plane and will give it his usual through inspection, but I am trying to fully cover the items as well.
    The FAA says use a checklist. They say that it can be from the manufacturer, self-produced, or whatever as long as it covers the territory described in Part 43 Appendix D. I like to have a checklist where I can make notes and check off items as I do them so that at the end I can see that I haven't missed anything.
    My Univair reprint of the Taylorcraft BC12D Service Manual has an inspection check list, but my plane has been upgraded with a C-85 and electric system so there are a few more things to look at than in the original manual. Searching the forum, I see that back in 2008 Mark Julicher scanned and OCR'ed the check list. Then there is the thread from a few years ago attempting to put together a checklist. But nothing really complete was ever forthcoming that I can find.
    Well, never one to shy away from embarrassing myself in public, I took Mark's scan/OCR and did my own scan/OCR and then merged and edited it to add the C-85 bits along with some different font sizes and formats to make the list easy to read on the table in the shop. I added some little circles to the front of each item because I like to have a defined place to make a check mark as I go along. I added sections near the end for electrical stuff. It seems funny that the original didn't have that. Most Taylorcrafts were wired for position lights and a ground-chargeable battery box. I have done some minor re-wording and added an item to lube and inspect the trim mechanism back in the tail. I have added items to check the strut ADs.
    Here is a PDF of my first attempt. I am using it now and it seems to work fairly well so I thought I would throw it out to all you guys and gals to read, nitpick, discuss, edit... hopefully improve. I will be glad to stick the source were as well as the PDF if folks want to play with it themselves. Being an old Unix guy, the document is done with Open Office / Libre Office in open document format. It may be readable by Word in Windows, but I have no way to check.
    I used a few criteria that seemed to drive me putting this thing together. This might help when we are discussing differing or conflicting goals.
    • First and foremost the check list should be usable to guide an annual inspection.
    • This is not "official". My IA has his own check lists and procedures that have served him well for many years. This is intended to be a guide for the interested amateur like me.
    • The check list should cover both the common BC12-D and also the BC12-D-4-85 STC'd for the C-85 upgrade.
    • The check list should clearly contain everything in the original service manual. Wouldn't want some slimy lawyer-type complaining that we didn't follow the "expert guidance". Am I missing anything?
    • The check list should cover Part 43 appendix D items. Again, Is anything missing?
    Hope this is useful. I'm looking forward to improving it.
    Attached Checklist PDF
    Skip Egdorf
    TF #895
    BC12D N34237 sn7700
    Re: Annual Inspection Checklist
    Hi Skip
    Attached is a check list I use when performing annuals, I like this lay out as it provides references and concept for findings good bad or indifferent. If is over kill to some degree for T - Craft, I simply NA the area and move forward.
    Paul
      Paul,
      Thanks for posting your list. I especially like the references to the regulations.
      I've used mine for a couple of years now and have thought about upgrading the form to more table-structured entry like yours. Even in its rough form, I now keep each filled check list with the year's numbers and notes in my aircraft records. It has been very useful a few times now to be able to go back and refresh my memory on just what I found a year or two ago. Your structure with the tables looks like it helps keep the comments and values organised better as well. I really have come to appreciate the value of a check-list like this for my personal record keeping.
      This will probably encourage me to update my forms shamelessly stealing everything from yours that I like. If/When I do, I'll post them here again so that we can all keep updating.
      Thanks again! I appreciate it.
      Skip Egdorf
      TF #895
      BC12D N34237 sn7700
        We are in the middle of an annual. I’ll drag this out and double check the AI.
