engine baffles
    Here are a few shots of the new baffles installed. Still a few tweaks to be made.
    Jason
    N43643
    Jason
    Former BC12D & F19 owner
    TF#689
    TOC
      J~
      Jason
      TF#689
      TOC
        N43643
        Jason
        TF#689
        TOC
          Jason,
          The installation looks great. Have you checked fit with the nosebowl? Hope the parts were helpful.
          Terry
            On my first attempt I did not thread the outer rods enough, so I took it all apart and fixed that. I never had a piece of baffle across the cases in front. Not even sure what it's supposed to look like. I do have a really hard time making the nose bowl fit, and was concerned about chafing. After 5 hrs of flight time I don't see any noticeable wear. The best part is NO MORE OIL LEAKS!!!
            Jason
            N43643
            p.s.
            Ron I received the stuff you sent.
            Jason
            TF#689
            TOC
              lower baffle pan
              Jason,
              The attached photo came from Capn Jons website... it clearly shows the lower baffle pan Ron is referring to.
                Oh, that baffle pan... Yeah I have one installed and it's also in need of replacement.
                I still think my nose bowl witch came off a Lyc. powered t-craft is dimensionally different than a Cont. powered one, and that is why I don't have much room up front since my ship is powered with an A-65-8. It appears to be narrower and not as deep. Can anyone shed some light on this subject? I would like to get a new one but I don't have the extra $$ at this time. Need more important things like a longer prop!
                Jason
                N43643
                Jason
                TF#689
                TOC
