shoulder harness STC/337
  • shoulder harness STC/337
    Well it is annual time and sad news, found metal in the screen. Bummer!
    Would like to install shoulder harnesses. Is there an STC out there for a 1946 BC12D? If so, would appreciate all info.
    ps.
    the above appears to say: ( to hell with the metal, put in harnesses)
    but it aint so!
    David Price
    N96045 #8245
    T-Foundation #558
    Molt Taylor Field
    Kelso,WA,
    David -
    I have a 337 for shoulder harness in my F-19. Are you still in Longview? If you can fly over to Chehalem (17S) tonight around 5:30 I will be there (I'm flying the 172 at 6pm) if you want to look at my installation. I can give you a copy of my paper work. You can call me at work 503.620.6601 x6029 if you want to talk or on my cell phone at 503.330.2647.
    BTW - are you going to fly down to the Taylorcrft Rendenzvous on May 14,15,16 in Columbia CA?
    - Carl -
      Carl, Thanks.
      Plan is, to be there if all else comes togeather.
      I will give you a call this evening.
      David
      David Price
      N96045 #8245
      T-Foundation #558
      Molt Taylor Field
      Kelso,WA,
        David -
        I will be out flying the Taylorcraft after work and probably won't get home until after 9 or so. You can try my home number 503.643.2274.
        - Carl -
          The FAA backed off on a lot a few years ago on the hassle of adding a shoulder harness to your airplane. Check around.
          This does not mean you can be silly in how you do it, but that the paperwork and approval process is a lot simpler.
          There is a "best practices" way to add it to your tcraft. Maybe someone here can post a drawing.
          good luck, and its a great idea to put it in.
          bob.
          Bob Ollerton
            rollerton contach tom baker at [email protected] i have some imformation on the a 40 con,t engine. thank you tom baker
              I seem to remember something like an advisory circular that was put out. Does that ring any bells with anybody?
              - Carl -
                Yep, there is a bunch of info on the FAA website. I'll see if I can find it.
                Blue Skies,
                Eric H.
                Madison, MS
                N39240
                  Found It....Pretty Good Information!!!
                  Don't need the 337, may not need the major repair, probably just a minor with an A/P signoff.
                  http://www.faa.gov/avr/afs/safety/harness/seatbelt.cfm
                  Blue Skies,
                  Eric H.
                  Madison, MS
                  N39240
                    Eric, Thanks for the info. This helps a lot!
                    David Price
                    N96045 #8245
                    T-Foundation #558
                    Molt Taylor Field
                    Kelso,WA,
