Long stem inner tubes for Shinn wheels
  • Long stem inner tubes for Shinn wheels
    The inner tubes that I have for my new to me tires have to have extensions on them or you can't even see them, they are inside the wheel. The stems now have about two inch long extensions on them, but I CAN'T get any of my tire pressure gauges to work.
    Are there a set of tubes that have the correct stems that are made for Shinn wheels?
    Re: Long stem inner tubes for Shinn wheels
    Hey Brie,
    Though this doesn't extend them, I bought an extension from the local Harley dealer that works perfect for mine. My stems barely come out of the wheel, and with the nut makes it even shorter. This extension, maybe around $10, screws on and then you fill the other end. Works great for my situation, as well as for my bikes. I was unable to put air directly in the stem on the wheel but this allows me to do so.
    This link is just to show you what it looks like, there are probably others similar to this as Harley usually buys from other manufacturers.
    Link: http://www.adventureharley.com/harle...nsion-42300009
