I'm thinking about making new safety cables that are covered to prevent chafing of the bungees.
I had a pair of bungees break a couple of years ago. I'm extremely grateful that the safety cables did their job and prevented the bungee breakage from causing any damage to my airplane.
On the other hand, the safety cables contributed to the failure because they abraded the bungees (I had seen bungees beginning to fray about a week previously and made a mental note to change the bungees at the upcoming annual, which they didn't make).
I recognize that covering them prevents inspection. My IA is OK with this.
I'll still use small plastic zip-ties to hold the new cables away from the bungees and to assure that they catch the LG when needed. This worked well when I had the bungee breakage (the zip-ties break away).
You might notice in the picture that the loops in the ends of the new covered cables are too small. I forgot to communicate the importance of the loop size to the company who makes the cable. So I'm having them make new ones with the right-size loops
