Wing Rigging
  • Wing Rigging
    Looking for wing rigging proceedure for Model 20. I have the info on flaps and ailerons, but nothing on the rear lift strut which has threaded attachment on upper end. The front strut is solid so dihedral is pre-determined at the factory. Also, if anyone has a picture or measurments of where the stall warning sits relative to the leading edge, I would appreciate that.
    Llewellyn
    Re: Wing Rigging
    I have it for the 15A if of any help.
    Chas. Tripp
      Re: Wing Rigging
      Thanks Chas, I would be interested in the information. The only difference I am aware of is the rib profile.
      Llewellyn
        Re: Wing Rigging
        From my owners manual. See Jpeg attached.
        I have 20 struts on a 15A. There were two wing construction types on the 15A, both same type cert. number as the 20.
        Best of luck.
        Charles LLewellyn Tripp
        Chas. Tripp
          Re: Wing Rigging
          Many thanks Charles...rec'd your PM. I like your middle name.....
          Llewellyn
