Can anyone share some propeller clocking wisdom? 60 degrees? 11 o'clock? 180 degrees?
Ok, it's been a couple weeks since I was able to fly, and I was not able to fly it after changing the oil and re-torqued my prop last time I went out. I had decided to rotate the prop according to these instructions (see attached)for a metal Sensenich on my O-320.
"Rotate the crankshaft by hand, until the engines number 1 cylinder is at TDC (Top Dead Center)... Locate the propeller on the engine flange with the number one blade at 11 o’clock."
Previously it was at about 1 o'clock and was installed by someone else. I did it because I noticed some slight vibration at about 2200 rpm in cruise and thought maybe it would help. When I flew the plane today, on the take off roll when I hit a certain speed right about before take off (if I remember correctly), I got some pronouced vibration and then it went away. I'm not sure if it's from the clocking or the fact that one of my tires was a little low on air. I am going to fly it some more hopefully in a couple of days and do some more investigation.
