F-19 wheel fairing hardware
  • F-19 wheel fairing hardware
    Greetings -- I am in need of some wheel fairing mounting hardware. I have the inboard mounts but I am searching for whatever was used on the outboard sides; not sure if this was a tube with welded nutplate on the end which fit inside the axle, or a combination axle nut/extension similar to what Cessna used (I tried one but the thread pitch is different). I believe I will also need something to protect the bearings since the cap (held on by 3 machine screws) that you attach the hub cap to can't be used -- If I remember correctly this might have been a piece of felt sandwiched between two aluminum washer-like pieces (held on by 3 machine screws). I am also interested in wheel fairings if you have them.
    If anyone has any parts they would like to sell, pictures of what they use on their aircraft, and/or measurements, or advice, it would be appreciated.
    Thanks -- David email [email protected]
