Any suggestions for sources or fabrication methods for the cowl bumps required to convert F19 exhaust to the Cessna 150 system?
Exhaust Conversion Cowl Bumps
Re: Exhaust Conversion Cowl Bumps
I'd contact Charly Center at: http://www.crosswindsstol.com He's a good man I've known for years and has done a few Taylorcrafts like the one below.Originally posted by N3787T View PostAny suggestions for sources or fabrication methods for the cowl bumps required to convert F19 exhaust to the Cessna 150 system?
Good find! Say hello to him from Gary Pearse in Fairbanks, and tell him I finally got another Taylorcraft after all these years.Originally posted by N3787T View PostThanks, Gary... Charly's got 'em!
Edit: I've got the C-150 system but no cowl bumps. Atlee Dodge modified the headers slightly to bring them in closer to the engine and clear the cowl.
GaryLast edited by PA1195; 09-03-2015, 14:17.N36007 1941 BF12-65 STC'd as BC12D-4-85
I like the idea of not modifying the cowling... I'll have to look into that. I'm running a SportCub-type system now, and it runs great, but haven't been able to get enough heat to the carb and cabin.
I'll pass on your hello to Charly.
Doug
One experimental change that works is to install a properly sized coiled door spring over the exhaust inside the heat shroud(s). First anneal the tempered spring with a torch, then wrap it around the pipe. Secure the soft spread coils to the pipe with safety wire here and there.Originally posted by N3787T View PostI like the idea of not modifying the cowling... I'll have to look into that. I'm running a SportCub-type system now, and it runs great, but haven't been able to get enough heat to the carb and cabin.
Doug
Make sure the coils can't contact and wear the external shroud. They're soft enough to not wear the underlying stainless pipe if properly secured. It acts like the flow interrupters Cessna and others fastened to the core of some mufflers to extract more heat.
