Switching a from A-65 to C-85-8
  • Switching a from A-65 to C-85-8
    Just couple notes that may help those that do this switch in the future.
    I assumed most all parts fit....wrong!
    Cylinder dia is slightly larger so some screws in the "between the cylinder" baffles need to be longer.
    You can stretch the existing A-65 baffling to fit but it makes it a PITA to work around the exhaust manifolds!!! Best build new.
    Exhaust manifold is approx 1/2" narrow between the two sides, needed to cut & stretch to make fit.
    I didn't need a long mount but thought we'd try a F-19 0-200 mount we had on hand for fitment, it would interfere with the stock exhaust.
    We ended up beefing up the stock 65hp short mount to match a 85-8 short mount.
    & NO it's not in the "certified" catagory...thank goodness!
    46 BC-12D Taylorcraft
    46 Chief
    Re: Switching a from A-65 to C-85-8
    Try Airforms Inc for baffles the ones i bought for my C85 were grate fit perfect and are cooling the engine well (907) 892 8244
