Pre-Heater Question
  • Pre-Heater Question
    I am putting on an EZ Heat preheater on my oil sump. Is there a preferred location...other than as close to the bottom as possible. Firewall side vs Front? Left or Right? Just curious...mostly concerned with cooling implications in the summer.
    Thanks...Homsie
    N95885
    Ashland, WI
    Re: Pre-Heater Question
    Just pretty much put it on the bottom so that no sides are above the oil line, if you put it above the oil line it will lead to early failure, I have the easy heat system before installing a rief system and I prefer it over the easy heat just because it is more thorough and a lot quicker
