A series and C series Continental (list archive)
  • A series and C series Continental (list archive)
    Doug,
    You really know how to ask simple questions! Sorry to be tardy in getting
    back to you but here is the first installment of the lineup as I see it:
    The A-40 is not part of the A series as it is a different design altogether
    and discussion of it will not be had here. See Chet Peek's new book "Flying
    with Forty Horses".
    All (the other) A series are 171 cu in displacement 4-cylinder with 3-7/8"
    bores and 3-5/8" stroke. The number after the dash is the rated horsepower:
    either 50, 65, 75, or 80. There is an obscure hybrid variant of the A
    series called the A-100 and that will be discussed at the end of the series.
    It is a favorite of mine.
    First, the A-50 series:
    The A-50 series dash numbers range from the -1 consecutively to the -9.
    Some A series have up exhaust, meaning the intake port is on the bottom of
    the cylinder and the exhaust port is on the top of the cylinder. Up exhaust
    engines include the A-50-1, -2, -3, -4, -5, and -6. The A-50-7, -8, and -9
    utilize a cylinder with a down exhaust. Some of the cylinders have only one
    spark plug hole, on top, with a cast boss where one could concievably add
    the lower hole. These are used on the A-50-1, -4, and -7 and, obviously,
    these engines only have one centrally mounted magneto driven directly by
    splines machined into the rear of the crankshaft. This makes this
    crankshaft very unique to the original A-50 series. This crankshaft equips
    my very orignal A-50-5 that utilizes dual mags, even though the splines are
    not used to drive anything. The A-50-2, -3, -5, -6, -8, -9 series all have
    two spark plugs per cylinder and use dual magnetos. The dual magnetos are
    driven off of a gear bolted to the back of the crankshaft so these mags turn
    the other way from the single mag setup. So some up exhaust cylinders have
    one plug and other up exhaust cylinders use two. Same for the down exhaust
    cylinders. Single ignition models were not allowed to be certified after
    11/7/41.
    The intake elbows used on up exhaust engines have a round cross section
    going to a round cross section. The intake elbows used on down exhaust
    engines have a square cross section going to a round cross section.
    Magnetos are generally the SF-4L or AM-4 (with left hand rotation) for the
    single mag and SF-4R or AM-4 (with right hand rotation) for the dual mag
    models. However, the A-50-2 is certified only with Dual Bendix Scintilla
    WL-4 mags or an Autolite IGW battery ignition (like the point system on
    your 1959 El Camino). In addition to the SF-4R and AM-4, the A-50-8 and -9
    can also use dual Case 4-CAMA mags. Magneto timing varies from model to
    model anywhere from 24 to 28 degress BTDC with some timing different between
    left and right mags. Impulse equipped magnetos and what they fit will be
    discussed later.
    The A-50 series engines utilize a 5.4:1 "low" compression ratio and utilize
    a different piston from the other horsepower engines because of this.
    Holding them in my hands, it appears to be the same casting as certain A-65
    pistons except that the flat top is machined a little lower. The low
    compression A-50 series makes its rated power at a low 1900 RPM but yet
    usually uses a really large prop. The prop for my Aeronca 50-C is a 76-51.
    Big diameter and high pitch. What? On a 50 hp engine? Compare this to a
    72-42 used on an A-65. Big diameter equals really big disc. Think how a 50
    hp helicopter can lift up vertically with a big prop turning really
    slowly... Don't laugh at a 50 hp continental...One famous modestly modified
    Aeronca 50-C flown by Johnny Jones flew from Burbank to NYC over
    Thanksgiving weekend in 1938 NONSTOP and landed with enough fuel to go 700
    more miles!! I would like to recreate this flight one day!!
    Some of the A-50 engines utilize a "dry" sump crankcase/accessory case combo
    utilizing a remote oil tank. These are the A-50-1, -2, -3. The accessory
    cases I have for these are both of magnesium and I do not know if any where
    ever available in aluminum. The A-50-4, -5, -6, -7, -8, and -9
    crankcase/accessory case combo all utilize a 4-1/2 qt. kidney "wet" sump.
    Obviously, a "dry" sump crankcase cannot be used with a "wet" sump accessory
    case and vise versa.
    A-50 series cases made prior to serial number 115395 (around late 1939) use
    a "hard mount" meaning that, if I remember right, four 5/16" bolts hold the
    engine to the motor mount without any rubber vibration damping. It was
    expected that the airframe designers would make motor mounts that would
    incorporate rubber suspension. This was rarely the case, however, and
    subsequent serial numbers incorporated the conical rubber mount bosses that
    we see most prevalent today.
    A-50 series engines generally are equipped with Bendix-Stromberg NA-S3,
    NA-S3A1 (the A1 meaning mixture control equipped), or Marvel-Schebler
    MA-3-PA carburetors. 1-1/4" venturis on the former and 1-7/32" on the
    latter. However, the A-50-4J, -5J, -6J, -7J, -8J, -9J models use a High
    Fuel Injector Model A in place of the carb, hence the J suffix. All other
    aspects of these engines remain the same.
    The unique crankcase, accessory case, and gear train on the
    A-50-6, -6J, -9, -9J allow the use of either an Eclipse Type 625 or E-80
    electric starter or a Mechanical Hummer X starter. The accesory case has
    the magnetos mounted horizontally, one left and one right with the "tops" of
    the mags pointing at 3 and 9 o'clock. Non-starter dual mag equipped
    accessory cases mount the mags almost vertical, one left and one right with
    the "tops" of the mags pointing at 11:30 and 12:30 o'clock. Conversion is
    difficult, if not impossible, because the 20 or so parts you need are
    scarce. If you want these features, you really have find an engine already
    with them.
    Some of the crankcases are cast and machined to accept an AC diapghram fuel
    pump just like the one on your 1959 Chevy El Camino. It runs off an
    eccentric bolted to the front of the camshaft. I am unsure if a fuel
    injected engine can be equipped with a fuel pump, though, because the fuel
    injector pump runs off of a gear that mounts to the smae part of the
    camshaft. The fuel pump equipped models were intended for use in low wing
    aircraft that had wing tanks, like the Ercoupe.
    All A-50 series crankshafts had an SAE No. 0 tapered output shaft and
    utilized a separate hub and key for attachment of the propeller. I have an
    original early A-50-5 and it is very apparent that the innards are of
    lighter wieght than later versions of the A series. The crankshaft has well
    drilled crankpins. The gears have lightening holes drilled in them. The
    connecting rods are a slimmer design. Nothing wrong with all this. Just an
    observation. I would not be using these lighter components to build up a 65
    or higher HP engine, though. So you have to know what you have.
    "Dry" wieghts range form 160 to 176 lbs.
    There are other comments to be made about the A-50 series but they will wait
    until discussion of each of the A series engines is complete.
    The A-65 is for next week.
    chris
    -----Original Message-----
    Sent: Tuesday, September 03, 2002 10:43 PM
    To: Christian Bobka
    Subject: Re: Pietenpol-List: A series, or C series Continental ??
    Chris,
    When I see manuals for these engines on E-Bay or wherever, they are
    always lsted as a "C", or an "A" series. I was just wondering what the
    difference was between the two. Here is a copy of what I've seen on the Net,
    A-50,A-65,A75,A-80
    C-75, C85, C90, 0-200
    Just curious if one is better then the other.
    Doug B.
    Do Not Archive
    Doug/Elizabeth Blackburn
    ArrowBear Lake Ca.
    Inland Slope Rebels, Riverside Ca. http://inlandsloperebels.com
    ----- Original Message -----
    To: "Twinboom" <[email protected]>
    Sent: Tuesday, September 03, 2002 7:28 AM
    Subject: RE: Pietenpol-List: A series, or C series Continental ??
    > Doug,
    > Two series? Do you mean the -8 vs the -12?
    > Chris
    > From: [email protected]
    > [mailto[email protected]]On Behalf Of TWINBOOM
    > Sent: Tuesday, September 03, 2002 8:33 AM
    > To: Pietenpol List
    > Subject: Pietenpol-List: A series, or C series Continental ??
    > --> Pietenpol-List message posted by: "TWINBOOM" <[email protected]>
    > Hey gents,
    > No big mdeal here, just wondering what the difference between the
    > two series would be, and is one better then the other. Thanks,
    > Doug Blackburn
    > Do Not Archive
    > ArrowBear Lake Ca.
    Roger,
    I believe there is a typo on the TCDS, at least the copy I have which is
    from the FAA website. Top of the page first line reads Models:
    A-80-5J, -8, -8J, -9, -9J. What is a -5J? They never mention it again.
    Likewise, the -6J is mentioned a bunch in the body of the TCDS but does not
    appear on the first line.
    I knew there was something about the A-80 that kept them out of most planes
    that did not have them originally. First, if you wanted to convert, you had
    to have an early enough case serial number and logbook. Then you would need
    to do the conversion and installation prior to 5/11/49. I guess it is the
    last line that kills it.
    Your tcraft down for rebuild?
    chris
      Doug,
      with Forty Horses".
      11/7/41.
      discussed later.
      with them.
      chris bobka
      To: Christian Bobka
      Chris,
      A-50,A-65,A75,A-80
      ArrowBear Lake Ca.
      Subscription; www.taylorcraft.org/links.html
      Archive; www.topica.com/lists/luscombe/read
      This email was sent to: [email protected]
      EASY UNSUBSCRIBE click here: http://topica.com/u/?aVxiHQ.aVzvsl
      Or send an email to: [email protected]
      T O P I C A -- Register now to manage your mail!
        Chris,
        What a wonderful dissertation on the A-50. I can hardly wait to read
        your entire series. Are you thinking of writing a book?
        I have a set of single ignition, upstack cylinders, complete with
        rockers, valves, pistons. All in really nice condition. I can't recall what
        they measured at, but can do it again. Do you know anybody out there who
        might be interested in them? A camshaft also came in the deal, and I have
        wondered if it is the same as an A-65.
        Dick Fischer
