Here are a few of my extended landing gear I am building. I designed a little set up for hydraulic branks that allows me to reduce the number of master cylinders by 2. Every ounce counts! Also- all the fluid is in the gear legs. I plan to finish welding it tomorrow. Next I have to build the axles for the 6.00x6 grove wheels I purchased.
Extended Landing gear photos
Eric Minnis
www.bullyaero.com
Clipwing Tcraft x3
Flying is easy- to go up you pull back, to go down you pull back a little farther.Tags: None
