Will a ellison run on a C-90 with out having more fuel pressure than from a wing tank.
ellison carburetor
Re: ellison carburetor
The EFS-3A will but you will need a small header tank a little lower than the carb for any negative stuff. It will do ok on 1/2 psi.Eric Minnis
www.bullyaero.com
Clipwing Tcraft x3
Originally posted by AcroericThe EFS-3A will but you will need a small header tank a little lower than the carb for any negative stuff. It will do ok on 1/2 psi.
Eric, Would the ellison run OK on just the fuel pressure a fuselage tank would provide ? (not sure what psi a fuselage tank provides...).
Thomas
It will do fine on the header tank head pressure in normal flight but again- any negative stuff would require a small header lower than the throttle body injector or a little FACET (brand) fuel pump. Easiest install is this little FACET fuel pump.
($100) with a small 12v battery- turn it on when you fly acro, off when you don't. The entire system is less than 2 pounds plus fuel flows through it- it can not stop the flow in any failure mode.Eric Minnis
www.bullyaero.com
Clipwing Tcraft x3
Thomas- I seem to remember that 14" = 1 psi. Anyone else check my math?Eric Minnis
www.bullyaero.com
Clipwing Tcraft x3
