Clipped T-Cart Leading Edge Ribs
  • Clipped T-Cart Leading Edge Ribs
    I need the help of the Clipped-T Clan to restore the leading edge ribs on my clipped T-Cart project.
    I am clipping a BC 12D using the Swick Conversion and about half the leading edge ribs are damaged due to corrosion--mice got to them while in storage.
    Does anyone have plans for a jig to make new leading edge ribs? I am (slowly) constructing one now using one of the damaged ribs; however, things would go much faster if I had plans for the jig. Can any of you help?
    Thanks.
    dd
    Remember: The fastest way between two points is full throttle.
    Re: Clipped T-Cart Leading Edge Ribs
    I take it you are using the aluminum ribs. .. . I have jigs for wood ribs and I have a box full of aluminum ribs if you need them.
    How far are you along on the project?
    Take care-
    Eric
    Eric Minnis
    www.bullyaero.com
    Clipwing Tcraft x3
      Take care-
      Eric
      Eric:
      Yes, aluminum leading edge ribs. I am interested, so let me know the cost of the ribs.
      As for the wood ribs you are building, are you using the NACA 23015 which is the one used on the T-Cart? Are they the truss-type?
      I am not far along on the project--basically in the tear down stage. I am in the Air Forced and resently stationed in Germany; however, plan to return this summer and resume the project. I hit 30 years in 2008 and mandatory retirement, so should have more time to devote to the project. Thanks for the reply.
      dd
        Actually the airfoil on the T is a 23012- same as the Model 12 Pitts, Samson, and I think the Beech Staggerwings.
        I will send you a PM on the ribs. I have tons of them.
        Eric Minnis
        www.bullyaero.com
        Clipwing Tcraft x3
          Eric:
          Thanks. Sorry about the mix up on the airfoil. I fat fingerd 23015 vice the actual 23012 like the on the Steven's Akro (Lazer). Did you receive my reply to your PM?
          dd
            I have lots of nose ribs for experimential ship.... They are the ones from the metal spar ships. $10.00 each . saves making them , can be adapted to any spar with a simple flange. Forrest Barber Taylorcraft Foundation [email protected]
              Forrest:
              Thanks for the offer. I have my buddies looking into the number of leading edge ribs I need. More to follow.
              dd
