Visitor Messages
  • Hi Buell,
    I got a question maybe you could help me with.
    I re rigged the plane and loosen the ailerons.
    Now my AP thinks they might be a little to loose, not used to t-craft rigging compared to cubs.
    Looking at the cables coming off the H frame with all those pulleys.
    When the yoke is moved forward and back the cable tension changes.
    My question to you is How loose should the cables be from the Yoke up to the back attachment point.
    I have the ailerons dropping about 1/4 inch and they go up in flight.
    Now about the cable tenon on the lower cables, When flying I can pull the cables by the door Post above the glare shield about an inch out from the post.
    Thats where my AI thinks its a little loose. I just wander how loose should it be.
    The controls are much lighter now and I hate to tighten them up to much.
    Thanks
    Robbie
    PS the struts came out good, got them done for $200.
    Robbie
    TF#832
    N44338
    "46" BC12D
    Fond du lac WI
