Re: 160 hp F-19
thanks for all the answers.
Not my aircraft.
Just trying to help a guy out that has it and wants it legal so he can fly it.
has big tanks, 180 mount F-22 cowl skylight etc.
160 hp F-19
Re: 160 hp F-19
You can switch to an F-22 Taylorcraft, it already has a Lycoming engine mount and the larger fuel tanks you will need. It also has flaps which are very useful. I believe the type certificate allows up to 180 HP. This would be a lot more useful of an airplane, and already has a higher gross weight allowance.
If you figure your time into it you will likely agree it is a lot cheaper than a 160 conversion on a B model, and there are far less compromises you would be making. Not to mention you'll be flying a LOT sooner.
Also, the F models have movable seats and larger baggage compartments.
Come to think of it, you can buy a 180 horsepower Auster "Workmaster" from England and get a very heavy duty bushplane that has everything you want in it already, plus control sticks, plus a skylight, and be flying in the time it takes to ship the aircraft over from England. Check the exchange rate, your dream airplane might already be sitting in a hangar somewhere with a for sale sign on it. Check www.austerclub.org and www.globalplanesearch.comLast edited by VictorBravo; 03-11-2009, 10:47.
Re: 160 hp F-19
You better have the big tanks holding 36 gallons becasue that is the biggest complaint. At 24 gallons with two 6 gallon wings and one 12 gallon nose youOriginally posted by S2D View PostDoes anyone have 337 for installing a 160 hp Lycoming in the F-19?
I know one in Alaska was done, looking for another to back up my field approval attempt.
Thanks
Brian
are on reserve in under three hours .
Re: 160 hp F-19
Maybe this is what you are looking for???
Edit- Never mind, that is for a Stinson I believe.Last edited by akndrifter; 03-09-2009, 21:04.
Re: 160 hp F-19
I'm not sure which one of them did those conversions, but I may be able to figure it out. If I do I'll let you know.
Re: 160 hp F-19
Thanks
I'll google it, but not sure who you mean to ask.
Brian
Re: 160 hp F-19
I think that is commonly called the Alsworth Conversion. You may want to try to ask them.
160 hp F-19
Thanks
BrianTags: None
